2 years 6 days ago
#3517
rechead,
I just followed the documentation excerpt that cjisble has in his response and Linux Terminal is now working fine on your system. You probably won't need it, but I just wanted to be sure that the documentation is correct. There are a few changes that are needed, I just need to figure out what article that was in :)
2 years 6 days ago
#3518
I should have just posted the link, but it was a long document.
allonis.com/support/documentation?view=category&id=426
2 years 6 days ago
#3519
Thanx as always cjisble. I modded the document a bit.
2 years 6 days ago
#3520
Thanks guys.
Any advice on getting the AppleTV working? I'm tempted to delete and redo it.
2 years 6 days ago - 2 years 6 days ago
#3521
We looked at it
You did not get the 2nd companion auth token in the procedure so Apple didn't allow the connection.
step 1 was to PairAirPlay. You must have done that.  Step #2 was to PairCompanion.    Similar process as PairAirplay but token (a NEW Token - not the same as step1 which it looks like got copied to the second "Members" field.
It if vitally important that you follow the instruction line for line, crossing off each instruction line as you perform that task.
These devices are very picky.
Last edit: 2 years 6 days ago by David Li.
The following user(s) said Thank You: rec head
2 years 6 days ago
#3522
Ugh. I meant to check that. I definitely did do the second step but obviously I pasted the same code twice for Notes and Members. This one I'm actually a bit embarrassed by.
Time to create page: 0.356 seconds
