#3483
The htp needs to be turned on by ir. The driver DOES NOT work for power on commands.. this is NOT new I brought this up months ago and was told to investigate it myself.
Last edit: 2 years 1 week ago by Fattykidd.
#3484
Thanks @fattykid. I thought there was something about the HTP-1 that required IR. It has been a while since I tried setting this up and have forgotten some details.
The Monoprice HTP-1 is a pre/pro and Allonis does have a driver for it so you guys have looked into it at some point. It was one of the drivers I updated yesterday. Driver date 2025-07-20. I don't know much about this stuff but the entire UI was re-written by a user so it is probably one of the more flexible devices of it's type. That UI was then adopted by Monoprice.
I have no idea what the network issue is. Everything else is pretty snappy. Even using the SR to browse through the Shield. I can try restarting it later when people aren't using it for work.
Myserver doesn't have wifi, right?
Last edit: 2 years 1 week ago by rec head.
2 years 1 week ago
#3485
The myServer controller does have Wifi (that by default is disabled) but I hope that wouldn't fix anything because a ethernet cable should always be better than a WiFi signal (assuming it's a decent network).
If you wanted to enable Wifi, here is info on how:
See the "Tidbits" section at the bottom.
We will log into your system later today to see if something looks apparent of why the lag.
2 years 1 week ago
#3486
My network is an eero pro 6. This year I bought new switches for the wired devices. I can't remember what they are but they are modern.
Thanks for looking into it.
2 years 1 week ago
#3487
Yes, Allonis can confirm that Monoprice did not enable Power on via Ethernet on the HTP-1
#3488
You would have to put a IP2IR GlobalCache to control the HTP-1 via Infrared as the Monoprice engineering team did not enable power on via ethernet. Allonis can reverse engineer this if someone finds it worth the development time and expense (like a few hours worth).  We did enough reverse engineering today on your system to confirm that this is doable.
Last edit: 2 years 1 week ago by David Li.
The following user(s) said Thank You: rec head
Time to create page: 0.410 seconds
