2 years 6 days ago
#3508
From a Browser, go to myServer Dashboard. click Utility Tab. Click Terminal Window choice. Permission AppleTV from that window as that is from the perspective of myServer 6 controller for the permissions to be set. I haven't tried this but that's one of the reasons we added that capability.
2 years 6 days ago
#3509
Hey David. I thought you needed to "upgrade" your myServer master image for the webui terminal to work ? At least that's how the documentation read.
2 years 6 days ago
#3513
I just hooked up a keyboard and mouse to the server and was able to add the AppleTV. But like everything I have done it is one step forward and one step back.
The server and AV devices are on the same monitor. From a remote computer I am able to use Driver Command Testing and move around on the AppleTV start shows, play/pause etc. In other words it works. It doesn't work on the myremote. Also there are now two AppleTV icons on the remote. Neither works.
2 years 6 days ago
#3514
David, I don't have the option: "Terminal Window choice" under Utilities. Only "Linux Termianal*"
2 years 6 days ago - 2 years 6 days ago
#3515
From the Documentation.  Notes added in parenthesis by me.
Linux Terminal Window
myServer includes the mean to open a webpage from any connected browser and to open a terminal window where you can interact with the operating system.  To use: go to Dashboard, click on Utilities, and then click on Terminal Window.  (SHOULD BE UPDATED TO SAY Linux Terminal)  A browser will appear.  You can right click and change the color of the font.  Remember, the user ID is "allonis" and the password for myServer OS is also "allonis".  With great power comes great responsibility.  Note that you are interacting directly with the operating system so you shouldn't issue commands that you aren't familiar with their result.
If you are not using the latest master image then:
In a terminal window: (NOTE:  I installed PuTTY on the PC where myDesigner is installed to open a remote terminal window.)
// ShellInABox
sudo apt install openssl shellinabox
sudo nano /etc/default/shellinabox
Change SHELLINABOX_ARGS="--no-beep --disable-ssl"
sudo systemctl restart shellinabox
Note that the myServer controller OS user name is "allonis" and password is also "allonis".If you want to enable SSH or VNC, from the terminal type raspi-config. Under interfaces, select and enable SSH and VNC.
Last edit: 2 years 6 days ago by cjisble.
#3516
Thanks, but I still get "refused to connect" when I click on Linux Terminal.
For some reason in Soureces & Apps &Pages I had 2 AppleTVs. I deleted one and that removed it from the remote but it still doesn't work. Driver Command and Testing still does work.
Last edit: 2 years 6 days ago by rec head.
Time to create page: 0.344 seconds
