Sprinkler Relay Questions
Chrisan's Avatar Topic Author
Re: Sprinkler Relay Questions
6 months 3 weeks ago
#4841
Finally getting this project going and a new question came up.   These IP relays are on network 192.168.1.   My home is 192.168.10.   Not sure how to get the two talking.   Router is pfSense.   Any quick ideas?  thx
#4842
Yes, change the relay IP to an address that is on your myServer subnet.  It "must" be configurable.
#4845
You might want to double check your ip address. "192.168.10" is not a valid IP address (it is missing a fourth number).
Note that IP addresses (V4 format) are four numbers, i.e. "192.168.0.10". The first three numbers must match if you are on the same internal LAN, or you have to make adjustments to route between them.
#4846
I assumed he was just abbreviating instead of "192.168.10.0/24"
#4850
David - correct.
6 months 3 weeks ago - 6 months 3 weeks ago
#4851
For a /24 network (most common) yes...but a 10.X and 1.X addressing can work for a /16 network with a subnet of 255.255.0.0
Just tidbits of networking minutia. :)
More importantly, to test the QuickReply feature of the forum :)
Last edit: 6 months 3 weeks ago by David Li.
Time to create page: 0.356 seconds
