Sprinkler Relay Questions
Chrisan's Avatar Topic Author
Re: Sprinkler Relay Questions
6 months 2 weeks ago
#4854
OK some progress.   I disconnected my desktop from the internet and gave it an IP in the 192.168.10 range.   I then hooked up the IP Relay box directly to the desktop and gave it an IP of 192.168.10.25.   After setting my desktop back to dynamic addressing I can now access and control the relay box on my regular home network by simply typing its IP 192.125.10.25.
But I can't get MyServer to control the box.  I'm getting a log message to the effect I need to use an "absolute URL."   So I tried http://192.168.10.25/30000 for the controller address.  And some other variations.   No luck.   Not sure what format to use to satisfy MyServer.   Thx
#4856
Does that sprinkler relay device need an IP port? If so, then the proper syntax would be: http://192.168.10.25:30000
You also might try using "https" to see if that would work.
#4857
Thanks.  I tried that format.  It doesn't work typing it into a web browser.   And it doesn't work as an address in MyServer.   Still stumped.
#4858
What relay are you trying to use? Where did you purchase it from? The driver supports specific hardware.
#4859
NC800.   They're sold under a number of marketing names, including Sainsmart.
6 months 2 weeks ago - 6 months 2 weeks ago
#4860
No idea if the driver supports that.
SainSmart is like saying "Chrysler".  They manufacturer and distribute many products.  The myServer driver was written for a specific product (that Allonis sells).  Not all SainSmart products.
Last edit: 6 months 2 weeks ago by David Li.
Time to create page: 0.356 seconds
