Jim Peduto's Avatar
thanks for the reply. Looks like we are stuck.
This is a lot more work and technical than I bargained for.
Know anyone that would like a hot deal on a remote and server?
I wouldn't give up that easily. If it's a problem with the driver then I expect it would be easy enough for Allonis to sort out.
I just released an update to the Harmony driver. The previous version would not try to reconnect to a hub if the hub disconnected. That's why restarting myServer made it come back. An big oversight on my part.
I also increased the discovery ping time out to 1500 milliseconds. This should make discovery more reliable on slower networks. Downside is that the discovery pass will take a bit longer to run.
Please update to the latest driver and see how that works. If there are any remaining issues I will have to remote into your systems to get more information.
CrabbyP can you email me your myServer teamviewer ID. And could you also install TeamViewer on the pc where you are using the Designer? I want to see if I can see and resolve your issues. If you have previously sent this info to David kindly froward it to me. dave@allonis.com
FattyK email me the teamviewer id of your server. I'll remote in and look. dave @ allonis.com.
Same holds true for anyone else. If I get inundated with requests I'll process in the order they come it.
Updated the Harmony driver. Did a getConfig - it worked. Left it alone for half an hour. Did another getConfig - it worked straight away. So it looks like the disconnect problem is probably solved (I only say probably as my wife is watching TV so I can't test out actual remote control commands).
Time to create page: 0.768 seconds
