#872
That's up to you David.
I've followed the directions with no luck. I've removed the driver and reinstalled with the same results.
I tried rebooting the router since it hadn't been done in a while, the hubs are 100% online and myServer hasn't had a problem finding other sources on the network.
I thought maybe the issue was with my harmony password, as it's been bugging me to make a "more secure" password for a while so I went ahead and did that.. still no luck.
When pressing the "discover" button it scans the network, stops for a second at the ip belonging to my apple tv (192.168.50.79) then proceeds right past the two addresses belonging to my hubs finishing off with no returned results.
I only have 45 minutes or so a day I can tinker with this so it's real slow moving for me but it's frustrating to not make any progress on something that should be so simple. I know it's gonna be something absolutely "dumb"
Last edit: 2 years 8 months ago by Fattykidd.
I updated Linux, updated smartremote template. You had downloaded the current, but hadn't changed it's name to "smartremote" so it wasn't being put into practice.
The AndroidTV driver didn't have the SmartRemote configured. The SmartRemote must have been offline so I couldn't do that for you.
The Roku driver needed to be redone. I started doing this but wasn't able to complete due to Teamviewer not allowing access.
You had your user name entered twice. I deleted one of them.
I added samsung TV, assumed it is in the Living room. I think I saw you authenticate it.
That's as far as I got.
Let me start by saying, thank you.
Smart remote is still in the box, haven't seen a need to open it since I only had the living room Roku that was "correctly" in it's place. I was trying to start simple by only adding a device at a time, apparently it bit me in the rear. The two rokus  for my daughter's would not show in "sources". And I have no idea how it even knew about the Roku ultra in the theater because it's been offline for longer than I've had myServer. Hagateway driver possibly?
I had renamed the template sample previously, but again after chasing down why I couldn't access the projects on windows 10 I took a break from it. (It was group policy permissions, btw)
Going forward, when an update is downloaded for the smart remote  template. It must be renamed immediately?
I can make that part of my "update routine",
Which username?
Any chance you were able to troubleshoot the harmony not populating ?
What still needs to be done on the Roku driver ? Should I just delete the devices and reconfigure?
JGrana01's Avatar
Jim Peduto's Avatar
The SmartRemote is showing icons on the home page, but when you click on them, they do nothing.
I saw the post re macro, and mine look fine.
The Smart Remote worked well last evening.
Suggestions?
See the post by DaveP today on fixing that issue. That's what I was going to do last night but then TeamViewer refused to allow my access.
Time to create page: 0.749 seconds
