HiSense TVs
Re: HiSense TVs
10 months 4 weeks ago - 10 months 4 weeks ago
#4596
If Roku, then the Roku docs / driver will work.
If AndroidTV, then use the AndroidTV driver.
There is no HiSense proprietary driver available. Low demand.
Sony / LG / Samsung is 85% of the US TV market.
All the other brands share the remaining, most of which are supported by AndroidTV or Roku operating systems.
Last edit: 10 months 4 weeks ago by David Li.
Mr_Orange's Avatar Topic Author
Banned Banned
Re: HiSense TVs
#4598
It has the Vidaa system. The specific model is 65Q6NAU.
Re: HiSense TVs
#4599
Try Roku or AndroidTV...if none work, then there isn't support for that TV.
Re: HiSense TVs
10 months 3 weeks ago
#4601
It may not be obvious to newcomers to this technology, but there are different ways of controlling devices: IP Control, IR Control, Bluetooth, for example. IP Control (Internet Protocol) uses a Wifi or ethernet signal to send commands, IR Control (Infra Red) sends an invisible light to the device, Bluetooth control sends a bluetooth radio signal, etc. It is usually desired to use IP control when available, as it is the most efficient and versatile. But IP control requires in depth knowledge of the devices API (which is often proprietary and not released by the company producing the device), so third party companies will not usually make that effort for devices that are not extremely popular.
A lot of devices that have IP control will also have IR control. It appears to me that this Hisense model does use IR control. So instead of trying to use IP control drivers (which in this case does not appear to be available for this TV, which most likely will be true from any remote control company), control of this TV should be done using the Allonis generic IR driver.
There is good Allonis documentation on IR setup, and the recommendation of the Global Cache IR emitter works well for me. Most likely the Hisense IR commands will be available in the Global Cache database, and if not, you can  also "teach" the codes.
I actually prefer devices that have IR control, since I know I can make them work.
Banned Banned
Re: HiSense TVs
#4602
I'm aware of all that. I have a Harmony Touch with Hub at the moment, which uses IP, IR and Bluetooth and it just works, including controlling my HiSense TV via IP. It was also very straightforward to set up with a good user interface and documentation.
As it stands, myServer is NOT a prime time universal remote control platform. It might be one day and I'd like to see that day but having to spend hours/days/weeks hacking your way through setting up every single command is not a good user experience.
The attitude of 'we cover 85% of the market and if your device doesn't work, that's too bad' doesn't exactly promote sales does it!
Re: HiSense TVs
#4604
No control system supports all devices. No exceptions.
And, what I said was Sony / LG / Samsung that THEY support 85% of the US market. And that Between ROKU and AndroidTV that might be another 10%. and there are other TV specific drivers like for Sharp. Maybe that's 90% of the total TV market.
Then, there is Infrared. I would bet that myServer supports the HiSense TV via IR. But my guess is you haven't purchased the correct hardware to test that as you are still in Trial of myServer.
The SmartRemote is the MOST capable remote control platform on the market. Period. Not sure what Prime Time is...something you buy at WalMart or HomeDepot? No, it's not that. Not sure what the equivalents are in your country. Far exceeds the customization capability of Harmony. But yes, with that power comes some education and understanding and experience needed, which you don't seem to have the appetite for.
BTW, if you have a Harmony Hub....then you can control the HiSense via the Harmony Driver that myServer has.
Certainly you aren't the target client for this product.
Time to create page: 0.387 seconds
