State Varible
Sat32's Avatar Topic Author
State Varible
2 years 16 hours ago
#3542
I really like the new Linear VU but loading from a overlay upon a volume change is to slow to be functional. But playing around with the slider I found using a state variable to hide un-hide makes this type of gui element actually usable. I could just use a panel to hide the control when not in use but I'm using a textured background that wouldn't line up right. So any chance there could be state variables could be added to the linear VU and other gauges
Re: State Varible
#3566
Two videos of some of the idea I've been playing with the second relies on state variables alot instead of loading overlays to make remote more responsive.
Opinions??
Last edit: 1 year 11 months ago by Sat32.
Re: State Varible
#3567
youtube.com/shorts/2ztw9DdHpko?si=S1EgHePTPP74l25r
don't know why but wont let me link 2nd video
Re: State Varible
#3569
That's a clever setup you've got there! I'm particularly intrigued by what looks like a drop down menu for your surround mode.
I also found using these kinds of widgets in an overlay to be unusable so I might have to steal some of your ideas here. Hope you don't mind!
Re: State Varible
#3571
The drop down is super easy to setup the only issue is the font can't be adjusted so it's a little small.
That setup was done with a overlay loading on volume change or mute with a transparent button the entire size of the screen, So touching the screen would cause it to load into a scene that used visible on load with the volume overlay
Mute Macro
Macro| // The macro is responsible for controlling volume muting in a room! AV|{{livingroom_avamp_id}}~Mute~<p1>! // gui settings! Math|Add~ui_{{livingroom_smartremote_id}}_controltime~{{current_uptimesecs}}~0! if|IsEQ##{{ui_{{livingroom_smartremote_id}}_controlon}}##false##SetVariable|ui_{{livingroom_smartremote_id}}_activescene~{{activescene_smartremote}}! if|IsEQ##{{av_{{livingroom_avamp_id}}_mute}}##1##SetVariable|ui_{{livingroom_smartremote_id}}_controlon~in-use! if|IsEQ##{{av_{{livingroom_avamp_id}}_mute}}##1##WebCmd|{{clientname}}~Show|control-overlay! if|IsEQ##{{av_{{livingroom_avamp_id}}_mute}}##0##WebCmd|{{clientname}}~refreshpage! if|IsEQ##{{av_{{livingroom_avamp_id}}_mute}}##0##SetVariable|ui_{{livingroom_smartremote_id}}_controlon~true!
Volume
Macro| if|IsEQ##{{av_{{livingroom_avamp_id}}_mute}}##1##SetVariable|ui_{{livingroom_smartremote_id}}_controlon~false! // The macro is responsible for controlling volume in a room! AV|{{livingroom_avamp_id}}~Volume~<p1>~3! // Commands for volume gui! Math|Add~ui_{{livingroom_smartremote_id}}_controltime~{{current_uptimesecs}}~3! if|IsEQ##{{ui_{{livingroom_smartremote_id}}_controlon}}##false##SetVariable|ui_{{livingroom_smartremote_id}}_activescene~{{activescene_smartremote}}! if|IsEQ##{{ui_{{livingroom_smartremote_id}}_controlon}}##false##WebCmd|{{clientname}}~Show|control-overlay! if|IsNE##{{ui_{{livingroom_smartremote_id}}_controlon}}##in-use##SetVariable|ui_{{livingroom_smartremote_id}}_controlon~true!
Exiting the scene with
Macro|LoadScene|{{ui_{{livingroom_smartremote_id}}_activescene}}!
That was saved with volume or mute returning to whatever scene you started at.
I keep changing the gui finding new ways to do stuff right now the gui in the second video is what I think I'm going to stick with.
If you see something and want to know how don't hesitate to ask
Re: State Varible
#3578
This looks pretty straightforward so I should be able to adapt it without too much difficulty. Thanks! It's fascinating to see what design choices people make when they decide to push things beyond the default template.
Time to create page: 0.489 seconds
