Exit SmartRemote
camens's Avatar Topic Author
Exit SmartRemote
9 months 1 day ago
#4735
From reading the docs, it looks like to exit the SmartRemote software I long press 'Home', so about one second.  That is not working as doing that just reloads my index page.  Could I have messed up something in Designer to stop that from working?  Or what else can I try to exit the smartremote.
Re: Exit SmartRemote
9 months 1 day ago
#4736
Well, you can make a long press do whatever you want it to do. You would inspect what it is currently programmed for using myDesigner. Open the current webpage (the home page is index.html) and see the button properties on what it is assigned.
But the three dots are what typically is assigned to go to the settings where Exit is located.
9 months 20 hours ago
#4737
Yes that worked! Didn't realize it was in that mode because the screen didn't change. I appreciate the help and fast replies as always David.
Time to create page: 0.331 seconds
