Sony Blu-Ray over IR
Matt22's Avatar Topic Author
#2674
I have a Sony Blu-Ray player I'm trying to use over IR. I'm trying to figure out what driver I would use for it since I don't see a specific Sony IR driver.
 I did some testing using the "Sony Most Used" IR command set and it works but I have to double send the command. Is there a way to make the IR signal last longer or double send each command?
Thanks..
Last edit: 2 years 4 months ago by Matt22.
Re: Sony Blu-Ray over IR
#2678
Sony's love to have repeat codes. Sometimes 2 mostly 3. Install today's server update.
Then go to the IR Database page. Expand the model for the Sony Bluray. It probably has codes that look like the following.
The first two numbers in the IRCodes are the frequency and repeat count. Repeats default to 1. We're going to change this.
Pull down the IR Command Testing and use the new SetIRRepeat command.
Select the Sony model name and set the repeat to 3 and execute.
Refresh the grid and you should now see the IR repeat count on the IR codes set to 3.
Now you can test on the live bluray player. If you are getting multiple button presses then the repeat count is probably too high. Go back in and drop it to 2. Experiment until you find the sweet spot.
#2685
Thanks Dave I appreciate the detailed reply.. I will give this a try.. My only other issue is what Driver do I use for the Sony Blu-Ray player so it shows up as an option on the remote?
#2689
What Driver do I use for the Sony Blu-Ray player so it shows up as an option on the remote?
Thanks..
#2690
I believe you would use the Bluray Player IR control driver. So you load your IR codes into the IR database. Then in the Bluray Player IR control driver you point it at the IR codes that you added to the database.
#2691
Thanks so much.. I'll give that a try..
Time to create page: 0.373 seconds
