2 years 3 months ago
#2768
Looks like I figured out how to insert images at least
#2769
Should I delete the unwanted devices from here:
What I don't understand is why those are even there if they aren't in my drivers.
Last edit: 2 years 3 months ago by rec head.
#2770
Might have been old information? Delete all that aren't going to be used. Clean it up for organization.
#2771
That leaves me with this
The tv and shield aren't there.
I have put the TV in the room
And then there is the My designer. I still can't do anything in the video. I found the right template to follow along (I think I don't think it is ever mentioned) but I can't even do the first step which is add an image. At this point I don't even care that the weather app shows the weather in the video but doesn't in mine. I just want to add a photo. I've tried about 20 times.
#2772
Renaming the TV by taking the spaces out got it listed in the Sources & Apps By Room page but renaming the Shield did not help.
#2773
Generally:
1) you add your room names
2) you add your device drivers for your hardware from Software Updater
3) you add your devices in the corresponding driver
4) you add your device to a room
That's the right steps, in the right order.
Please ask other myDesigner questions in their own thread (in the myDesigner section)
You don't need to do anything in myDesigner unless you want to customize the out of the box user templates.
Get the Allonis provided templates fully working first.  Then make it more complicated.
Last edit: 2 years 3 months ago by David Li.
Time to create page: 0.360 seconds
