If you want to have direct number import edit the CableTV page in the designer and change the commands under the numeric keypad to the following
0 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 0
1 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 1
2 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 2
3 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 3
4 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 4
5 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 5
6 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 6
7 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 7
8 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 8
9 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 9
Enter = AV|{{active_cabletv_{{clientname}}}}~Remote~Cursor Enter
if you want to see the numbers that you press echoed on the remotes screen then the button commands turn into macros like this
0 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}0!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 0
1 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}1!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 1
2 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}2!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 2
3 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}3!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 3
4 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}4!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 4
5 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}5!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 5
6 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}6!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 6
7 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}7!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 7
8 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}8!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 8
9 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}9!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 9
Enter = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~!AV|{{active_cabletv_{{clientname}}}}~Remote~Cursor Enter
Last edit: 2 years 4 months ago by
davep.
