How to authorize a hub
Dumb question of the day.
How do you authorize a hue hub for use with myserver.
I installed the driver, clicked discover, it found my hub and added it but gives me a warning that it needs to be authorized before use. Normally a push of the top button on the hub does this. It did not help with myserver.
JGrana01's Avatar
Re: How to authorize a hub
Try to first press the button on the Hue hub first, then execute the Authorize command on the dashboard
I also had a few issues, but the above method seemed to work for me.
Thanks jgrana.
I didn't realize the "authorize button" was in the command builder.
rookie mistake.
#752
I modded the document to make process clearer.  Thanx JGrana01
Time to create page: 0.316 seconds
