Chrisan's Avatar Topic Author
6 months 3 days ago
#4897
Interesting - typing R: into MyDesigner settings worked!    Thanks!
6 months 3 days ago
#4898
aa6vh can you add overlays using this in your MyDesigner settings? - \\192.168.0.65\myServer
6 months 3 days ago
#4899
That won't make a difference.  Anything with a \ is a Windows path, and is not case sensitive.  Linux is case sensitive, but only uses /.
6 months 3 days ago
#4901
This problem is fixed but I would like to understand it better, hence my question.  If he can add overlays using \\192.168.0.65\myServer in settings why can't I do it using
\\192.168.10.252\myServer ?   I suspect the answer is "no" but not sure.
6 months 3 days ago - 6 months 3 days ago
#4902
When you mapped the network drive, did it prompt you for a username and password?
When you enter a path in the form of \\<server>\<share>, it is evaluated on-the-fly.  MyDesigner doesn't seem to do any checking or error trapping, so any number of problems could have resulted in the crash.
When you map the network drive, windows negotiates with the other machine and sets up the connection, so it will "just work" for any Windows program.
I have a really old copy of Quicken, that will not do a backup to a network share.  But if I map the network share to a drive letter, Quicken thinks it is a local drive, and the backup works.
Last edit: 6 months 3 days ago by cjisble.
6 months 3 days ago
#4903
It did not ask for a username and password.   I have no idea what they even are.
Thx
Time to create page: 0.352 seconds
