Pages not loading
jacobgrahn@outlook.com's Avatar Topic Author
Pages not loading
7 months 1 week ago
#4819
Hello all, I am new to both myServer and myDesigner... one of the issues I am running into is that I cannot load any pages. When trying to open an HTML documents the page is just white/blank and does not seem to load. Attached screenshots of the issue as well as my current settings.
This issue seems to be present when running it in Windows 11 as well as throwing it in a Windows 10 VM for testing. Maybe I'm doing something wrong, not too sure. I did confirm the URL and File Share are correct.
Advice appreciated.
Thanks,
Jacob
Re: Pages not loading
7 months 1 week ago
#4825
Sounds like you have file sharing properties not set.
This is why I mentioned DON'T use a VM or Windows.
Just use a Raspberry Pi4 4 / 8 gig for easiest and best results.
7 months 1 week ago - 7 months 1 week ago
#4828
I should mention, I ended up caving and getting a Rasperry Pi 5 from Micro Center. The server does not seem to be the cause of the issue, but I could be wrong.
myServer is currently running on the Rasperry Pi 5, myDesigner I have tried both on Windows 10 & 11. I can see the files in the left-hand side of the window indicating that I have a connection to the server, but when trying to actually access any of the HTML pages, that is when I run into problems.
Thanks,
Jacob
Last edit: 7 months 1 week ago by jacobgrahn@outlook.com.
7 months 1 week ago
#4829
Did you follow the file sharing info on the docs:
allonis.com/support/documentation?view=category&id=191
Very common Windows PC setup issue for myDesigner.
Time to create page: 0.720 seconds
