make sure you download the appropriate web font files and put them in the smartremote/css/fonts folder.
then you have to edit the font-icons.css and add the appropriate font-face entries for each of the Helvetica font weights you want to use. You'll see entries like
/* designer-font:Roboto */
@font-face {
font-family:'Roboto';
font-style:normal;
font-weight:100;
src:url('fonts/roboto-v19-latin-100.eot');
src:local('Roboto Thin'), local('Roboto-Thin'),
url('fonts/roboto-v19-latin-100.eot?#iefix') format('embedded-opentype'),
url('fonts/roboto-v19-latin-100.woff2') format('woff2'),
url('fonts/roboto-v19-latin-100.woff') format('woff'),
url('fonts/roboto-v19-latin-100.ttf') format('truetype'),
url('fonts/roboto-v19-latin-100.svg#Roboto') format('svg');
you will need to add similar css entries for the Helvetica files.
The line that reads /* designer-font:Roboto */ is what informs the Designer that the font is available to use in the project. You would add a similar /* designer-font:Helvetica */ line at the top of your Helvetica font css font-face list.
Last edit: 2 years 3 months ago by
davep.
