Select room issue
Select room issue
I am thinking this started after updating to the latest version of MyServer. When I select a room I get the following error14/02/2024 19:10:09.10 · DEBUG · Server.doCommand - activate-room.activate-room.masterbr from moonlightdev-fx-fm4j14/02/2024 19:10:09.10 · WARN · Server.doCommand - Unknown command activate-room.activate-room.masterbr
Re: Select room issue
Look in the Macros page. There is no macro by that name. That's the error you see. Change the room to call the correct activation macro.
Agree, If I change the macro name to activate-room.activate-room.masterbr it works. The button was working with activate-room.masterbr earlier in the day,
Nothing is random (unless you intentionally make something random in a macro).
So, if the behaviour changed, then you changed something to make it change.
That's important so you can troubleshoot...ie: what did I change since then?
Open the macro that is firing (you can see which in event viewer) and then open that and see what it is doing (or trying to do).
Time to create page: 0.339 seconds
