Sorry for the delay in replying. With the new forum, I no longer see a list of recent posts, nor can I view the summary of my posts. I have to track down the thread manually to check for a response.
The problem is in the command builder itself. You can select SENDTEXT, but the only option under Command is "Not Supported". The Actual Command also just says "Not Supported".
Also, when I turn on Verbose logging in the Kodi Driver, the same messages repeat over and over in the log. (Note that I have two devices running Kodi.)
18/10/2026 11:09:55.09 · DEBUG · Kodi.TX:KodiTH - {"jsonrpc":"2.0","id":"Player.GetActivePlayers","method":"Player.GetActivePlayers","id":"Player.GetActivePlayers"}
18/10/2026 11:09:55.09 · DEBUG · Kodi.RX:KodiCE - {"id":"Application.GetProperties","jsonrpc":"2.0","result":{"muted":false,"volume":100}}
18/10/2026 11:09:55.09 · DEBUG · Kodi.RX:KodiTH - {"id":"Application.GetProperties","jsonrpc":"2.0","result":{"muted":false,"volume":100}}
18/10/2026 11:09:55.09 · DEBUG · Kodi.RX:KodiCE - {"id":"Player.GetActivePlayers","jsonrpc":"2.0","result":}
18/10/2026 11:09:55.09 · DEBUG · Kodi.RX:KodiTH - {"id":"Player.GetActivePlayers","jsonrpc":"2.0","result":}
18/10/2026 11:09:57.09 · DEBUG · Kodi.TX:KodiCE - {"jsonrpc":"2.0","id":"Application.GetProperties","method":"Application.GetProperties","params":{"properties":["volume","muted"]} ,"id":"Application.GetProperties"}
18/10/2026 11:09:57.09 · DEBUG · Kodi.TX:KodiCE - {"jsonrpc":"2.0","id":"Player.GetActivePlayers","method":"Player.GetActivePlayers","id":"Player.GetActivePlayers"}
18/10/2026 11:09:57.09 · DEBUG · Kodi.TX:KodiTH - {"jsonrpc":"2.0","id":"Application.GetProperties","method":"Application.GetProperties","params":{"properties":["volume","muted"]} ,"id":"Application.GetProperties"}
18/10/2026 11:09:57.09 · DEBUG · Kodi.TX:KodiTH - {"jsonrpc":"2.0","id":"Player.GetActivePlayers","method":"Player.GetActivePlayers","id":"Player.GetActivePlayers"}
18/10/2026 11:09:57.09 · DEBUG · Kodi.RX:KodiTH - {"id":"Application.GetProperties","jsonrpc":"2.0","result":{"muted":false,"volume":100}}
18/10/2026 11:09:57.09 · DEBUG · Kodi.RX:KodiCE - {"id":"Application.GetProperties","jsonrpc":"2.0","result":{"muted":false,"volume":100}}
18/10/2026 11:09:57.09 · DEBUG · Kodi.RX:KodiTH - {"id":"Player.GetActivePlayers","jsonrpc":"2.0","result":}
18/10/2026 11:09:57.09 · DEBUG · Kodi.RX:KodiCE - {"id":"Player.GetActivePlayers","jsonrpc":"2.0","result":}
18/10/2026 11:09:58.09 · DEBUG · Kodi.TX:KodiCE - {"jsonrpc":"2.0","id":"Application.GetProperties","method":"Application.GetProperties","params":{"properties":["volume","muted"]} ,"id":"Application.GetProperties"}
18/10/2026 11:09:58.09 · DEBUG · Kodi.TX:KodiCE - {"jsonrpc":"2.0","id":"Player.GetActivePlayers","method":"Player.GetActivePlayers","id":"Player.GetActivePlayers"}
18/10/2026 11:09:58.09 · DEBUG · Kodi.TX:KodiTH - {"jsonrpc":"2.0","id":"Application.GetProperties","method":"Application.GetProperties","params":{"properties":["volume","muted"]} ,"id":"Application.GetProperties"}
18/10/2026 11:09:58.09 · DEBUG · Kodi.TX:KodiTH - {"jsonrpc":"2.0","id":"Player.GetActivePlayers","method":"Player.GetActivePlayers","id":"Player.GetActivePlayers"}
18/10/2026 11:09:58.09 · DEBUG · Kodi.RX:KodiTH - {"id":"Application.GetProperties","jsonrpc":"2.0","result":{"muted":false,"volume":100}}
18/10/2026 11:09:58.09 · DEBUG · Kodi.RX:KodiTH - {"id":"Player.GetActivePlayers","jsonrpc":"2.0","result":}
18/10/2026 11:09:58.09 · DEBUG · Kodi.RX:KodiCE - {"id":"Application.GetProperties","jsonrpc":"2.0","result":{"muted":false,"volume":100}}
18/10/2026 11:09:58.09 · DEBUG · Kodi.RX:KodiCE - {"id":"Player.GetActivePlayers","jsonrpc":"2.0","result":}
18/10/2026 11:10:00.10 · DEBUG · Kodi.TX:KodiCE - {"jsonrpc":"2.0","id":"Application.GetProperties","method":"Application.GetProperties","params":{"properties":["volume","muted"]} ,"id":"Application.GetProperties"}
18/10/2026 11:10:00.10 · DEBUG · Kodi.TX:KodiCE - {"jsonrpc":"2.0","id":"Player.GetActivePlayers","method":"Player.GetActivePlayers","id":"Player.GetActivePlayers"}
