Differences between HA and myServer
#517
So I've my HA instance connected to myServer and it seems like it's working.  I can control my Anthem AVR and change the volume for example, but I've got a couple questions/discrepancies.
On the Anthem, in myServer I see 6 inputs listed Input_AV1, Input_HDMI1 through 4, and Input_Tuner.  However in HA there are 12 inputs listed, and they are named as I have them named as I named them in the Anthem setup.  I tried sending commands to change inputs (eg: AV|7~Remote~Input_HDMI1) from myServer but those don't work.  I get the following errors in the log:
08/02/2024 22:32:38.32 · DEBUG · Server.doCommand - AV|7~Remote~Input_HDMI1 from dashboard-fx-posm
08/02/2024 22:32:38.32 · ERROR · HAGateway.doCommand - Error in MoveNext - InvalidFormat: not a valid value for dictionary value @ data
The other question I have, I added the JVC Projector integration in HA for my X990 and got it setup, in HA it creates a sensor entity, and a remote entity, however only the sensor entity shows up in myServer.
I submitted the HA config as described in the documentation page.
Re: Differences between HA and myServer
Are you sure you set the input in HA using the remote entity and not the media_player entity?
Judging by the icon on the card, it's probably the mediaplayer entity.  That said, this is probably (hopefully?) moot with the Anthem driver coming shortly.
Time to create page: 0.352 seconds
