Activation
retate's Avatar Topic Author
Activation
How does one know when activation has happened? Are there any functional limitations until activation occurs?
I requested activation 24 hours ago. The license status field is still showing as blank.
Re: Activation
The license field should not be blank.  It should be Trial or Permanent (activated).  I assume you are looking at the Dashboard home page?
Post a print screen of what you are seeing.
When you requested activation...did you first completely fill out the Owner's info (including your email)?
Re: Activation
The License Type on the home page shows Permanent. It has never shown Trial to my knowledge. The configuration licensing tab shows the "License Status" field as blank. I assumed once the license was activated that field would show something other than blank. Screen capture attached. I had filled out the Owner Information page including email address prior to requesting activation.
Re: Activation
Permanent means lifetime activated. All od the shelf systems shipped preactivated. You are good to go.
Time to create page: 0.351 seconds
