Server device drivers - room selection by name criteria is for numeric values
retate's Avatar Topic Author
#2288
When configuring device drivers the ability to select by room does not work due to the search criteria for the Room column. The Room column has search criteria for a numeric field (Is equal to, Is not equal to, Is greater than or equal to, etc.). The column should have search criteria the same as the Name, Type, and Model columns have (Are Equal to, Starts with, Contains). For device drivers such as Lutron Caseta where there can be 75 devices being able to search by room name would be helpful. This problem with room name search criteria appears to be a general problem applying to all drivers. In other areas such as Configuration/Rooms the search criteria definition for the Room Name column is correct.
Last edit: 2 years 6 months ago by retate. Reason: Added a note that this problem may be limited only to the drivers portion of the interface.
Time to create page: 0.341 seconds
