Driver Releases
Re: Driver Releases
#2067
Dave,
Some time ago you released the Storm Audio driver.
However when I try to install it and my server restarts there is no evidence that the driver has been installed even though it downloads and says it has been installed.
I sent you my teamviewer ID by email.
Could you please investigate?
Thanks,
Hi, we are having difficulty teamviewing in...noticed you had VNC installed...not sure if that affects TV or not.
Can you carefully check if the "video=HDMI-A-1:"
mod was made to the sudo nano /boot/firmware/cmdline.txt
file?
reboot after you check and / or edit that file as per the instructions at the very bottom of that article.
Thanx
kirky27's Avatar
Re: Driver Releases
#2068
I added this text to read:
Edit: Other drivers install successfully when I do a test install -for example the Marantz which i tried to install this morning. Only the Storm driver fails to install.
Also when I check the documentation only the Storm driver is NOT listed -all the other receiver IP drivers are listed.
Last edit: 2 years 6 months ago by kirky27.
kirky27's Avatar
Re: Driver Releases
#2069
Also,
I don’t know if you were able to successfully log in but I notice that I’m unable to log in now.
I’m not sure if you made any changes to my system.
Re: Driver Releases
#2070
nope made no changes.  please make the changes in my last post and reboot.
kirky27's Avatar
Re: Driver Releases
#2071
Ok strange.
I made the edit (see my prior post) rebooted and was able to log in and subsequently the system went offline and now is unreachable.
Regardless, I’m wondering if the Storm driver needed some tweaking because as I said before I was able to install other drivers successfully -all but the Storm driver.
It looks as if I will have to rebuild my system from scratch as it is unreachable.
Re: Driver Releases
#2073
Ok strange.
System seems to be working fine now.  but I redownloaded stormaudio driver and it isn't loading...so we will take a look at it.
Time to create page: 0.411 seconds
