myServer supports receiving temperature values from a 1-Wire temp sensor DS1820
Requirements
- myServer
- 1-Wire DS1820 temperature sensor
- myServer controller
- GPIOgeneric device driver
Install the GPIOgeneric driver from within myServer's Software updater.
Wire the DS1820 sensor into the Raspberry Pi controller (running myServer)
Wiring:
Hooking it up
1. Connect GPIO GND [Pin 6] on the Pi to the negative rail on the breadboard and connect GPIO 3.3V [Pin 1] on the Pi to the Positive rail on the breadboard.
2. Plug the DS18B20+ into your breadboard, ensuring that all three pins are in different rows. Familiarise yourself with the pin layout, as it’s quite easy to hook it up backwards!
3. Connect DS18B20+ GND [Pin 1] to the negative rail of the breadboard.
4. Connect DS18B20+ VDD [Pin 3] to the positive rail of the breadboard.
5. Place your 4.7k? resistor between DS18B20+ DQ [Pin 2] and a free row on your breadboard.
6. Connect that free end of the 4.7k? resistor to the positive rail of the breadboard.
7. Finally, connect DS18B20+ DQ [Pin 2] to GPIO 4 [Pin 7] with a jumper wire.
Once connected, boot the myServer controller.
Immediately the GPIOgeneric driver should communicate to the sensor, and create a new device which will then provide it's temperature (both F and C) within myServer variables. These variables can then be used in user interfaces, rules, macros etc.
