Re: SmartRemote
#852
At some point Allonis changed something and now every time you exit the app it restarts it.  The only way I've found to stop that is to exit the smartremote app then try to quickly navigate to the settings and disable wifi.  After a little bit turn it back on and it should give you enough time to change things.  At least it did on mine.
That is the function of the AndroidTV driver....Keeps the smartphone UI working, even if shut off.  So, you can disable the AndroidTV driver to the SmartRemote, restart and it should stop that behaviour.  That's a feature :)
You can also run av|XYX~monitor~off command.  Where XYX is the SmartRemote device ID.
Time to create page: 0.464 seconds
