Blank multi colored screen and nothing else
Re: Blank multi colored screen and nothing else
1 year 10 months ago
#3737
When I type that into a browser I get the stock template, theateremote I get my remote page. However I cannot set this in the app, it is stuck on the multi colored screen and I can't get any further.
#3738
ok, switch the smartremote to use the stock template. Does that load?
#3739
I can't switch it on the remote, even if I reboot and quickly hurry to clear the cache in the app befoere it launches I never get the choices to point it to the template or server, I get the multi colored screen and thats it. Holding the home button, the back button, the 3 lines, or the 3 dots does nothing.
I am going to try the ADB method in the troubleshooting section later today now that its back on the wifi network.
#3740
Ok I was able to connect to the remote via adb and goto chrome://inspect I found the remote and connected to it. Changed the template to smartremote (from theaterremote, which is wrong it should be theateremote), the connections line is blank and there is no line for activeproject.
Nothing changes on the remote, still a blank colored screen.
So I reboot the remote, it goes through the cycle comes up to a android desktop, then a blank white screen, I see the allonis bar at the top for a second and then it goes to the blank colored screen. I connected again to the adb and the remote has defaulted back to the settings I found originally.
Also during this process another issue has come up. In order to connect a monitor, mouse and keyboard I had to move it to another room, it is headless in the server room usually. I shut down the pi from the web page. When I connected it to the monitor mouse and keyboard it wouldn't boot with a error part missing uuid initramfs.
I got to the shell and typed help then exit and it booted normally.
I am emailing you my teamviewer ID
Time to create page: 0.362 seconds
