Using both samsung drivers simultaneously. How to programatically select each?
Re: Using both samsung drivers simultaneously. How to programatically select each?
2 years 5 months ago
#2436
Hi, sure!
Yes I apologize as I didnt include all the "issues" as my post was more centered around tailoring a workaround for my own use...
I have 2 different Tizen TVs. One is a newer series (lets say TV1) , and one is a bit older (TV2).
What I have noticed:
Volume & Tizen Driver - Works correctly for both of my TVs.
Power & TIZEN Driver: TV1 (newer) OK! / TV2 (older) Discreet ON command toggles the power.  OFF command is correct.
Samsung Driver - Power discreet commands work OK for TV2, Volume doesnt work at all.
In summary my "issue" is only with 1 TV, with the Power... Thats why I thought about using the alternate driver for that one only... Maybe I can alter the macros for the Living room only (where the older TV2 is), as was suggested... I'm thinking what path is easiest and wont give more headache in the future... It seems to be only 1 TV giving me issues, so I also dont want you to waste time as I'm unsure there is a fix on the driver side... (at risk of breaking other TVs which now work on the same driver)... Let me know your thoughts if you dont mind
Could you just replace the power on command in the activation macro(and anywhere else you use the discrete power on command, like the power button) with a macro(ex: tv.poweron).  Then in the tv.poweron macro you have an If check that issues the Samsung Driver power on command if the active room is your living room and otherwise uses the standard {{{{activeroom_{{clientname}}}}_display_id}} power on?  That way everything uses the normal Tizen driver except the discrete power on command.
RoyN's Avatar Topic Author
#2439
Yep, will do that. Thanks for helping clear my mind on the easiest way to do it!! Thanks
2 years 2 months ago
#3107
HI RoyN, I saw your post on Unfolded Circle....so, how do you like your SmartRemote? Is it meeting your needs? Do you have a comparison with the Unfolded Circle remote? Thanx for the update!!!!
#3113
Hi David! I ended up selling the unfolded and staying with the Smart Remote instead... I am traveling for the past months but will return to the US where I have the remote at home in October... I'd say I'm about 80% there integrating everything I need... will update when i'm back ;)
#3114
Nice, thanx for the update. Was looking for someone who has experience with both systems.
Have good travels!!!
Time to create page: 0.422 seconds
