Linux install guide?
Re: Linux install guide?
#2480
allonis.com/support/documentation?view=category&id=226
But we don't recommend it.  That is adding many layers of complexity and likely unreliability to the system.  Not all features will work either.
It should work in general, however.
run51's Avatar
#2551
hello
I followed the myserver6-linux-debian-mint tutorial
The command to download myserver does not work.
The cloud link does not exist.
wget cloud.allonis.com/downloads/myServer-linux-x64.zip
In addition there is no command for the arm64 version...
THANKS
#2553
Download files are located here:
allonis.com/support/documentation/downloads
These instructions are a bit more complete:
allonis.com/support/documentation?view=category&id=416
Ignore the parts about setting up a Virtual Machine if you are not doing that.  Once the OS is installed, everything else is the same.
run51's Avatar
#2566
Hello
I would like to try myserver on my existing installation
I have an odroid N2+ with debian 12. I downloaded the arm64 version of myserver. Services myserver and myinstaller do not start. I don't see the problem
#2568
What you are trying to do is unsupported for the reasons you are running into trouble.
Highly recommended is to get a myServer controller and not have these installation headaches.
run51's Avatar
#2570
your controller is simply an rpi with debian like my odroid with debian.
I already have a home assistant installation on my odroid. I'm not going to buy an rpi just for myserver. It makes sense to install everything on the same machine.
This should work
Time to create page: 0.524 seconds
