IP Cameras - a struggle
Re: IP Cameras - a struggle
2 years 3 weeks ago
#3341
did you enable teamviewer and email the id and password? not supportable otherwise.
2 years 3 weeks ago
#3342
Please turn on TeamViewer that's the only way I'm going to find what the issue is.
2 years 3 weeks ago
#3355
Your software was out of date.  I updated myServer software and then updated OS.  You need to locally reboot myServer as it is now offline for remote access.  You may need a HDMI monitor / wireless keyboard to reboot.  That's as far as we got.
2 years 3 weeks ago
#3360
Many thanks for having a look, but it didn't solve the issue.
I think I may just proceed with my idea of running mediamtx on a separate server and accessing the stream URLs from the relevant MyDesigner 6 component.
I also want to explore doing some more bespoke things with the feeds.
An example of what I want to achieve (which I suspect I can't do via the MyServer and drivers) is to use FFMPEG to combine all four of my CCTV feeds into a grid and output that as a single video feed. I noticed the remote really struggling to display four simultaneous feeds so I want to put the hard work on the server and make it easier on the remote. Suspect I can't do that easily (or at all) via the built in drivers.
Current idea is that when a MediaMTX URL is accessed it triggers FFMPEG to combine the four feeds and MediaMTX serves them up as a single combined video. I think that will be much easier on the remote. I need the trigger in place as I obviously want to avoid a lot of system resources otherwise being used up combining video sources that are not being viewed.
I'll let you know how I get on. It doesn't fix the issue with being unable to configure the driver locally, but I can see that the idea of combining video feeds may be worth the additional effort.
2 years 3 weeks ago
#3361
fearnley, we never got to that. We updated the software, and OS and that's as far as we got. Please enable TeamViewer if you would like support.
Thanx
2 years 3 weeks ago
#3362
Now re-enabled
Time to create page: 0.367 seconds
